Concur Invoice - Importing Tax Amounts and Expense Types at the Line Item Level
Can you please vote for the following Solution Suggestion on Concur's site?  We need as many votes as we can get so that Concur makes the change to be able to import expense types and tax amounts at the line item level of the invoice:
Solution Suggestion ID # SS-0000024682
Concur Invoice - Importing Tax amounts and Expense Types at the Line Item level
In Concur Invoice, we need the ability to be able to import expense types (GL accounts) as well as tax amounts on the line item level.  Not being able to import/upload at the line item level (from an excel template) the expense types (GL accounts) as well as tax amounts is causing our employees extra work that we don't have time for.  We're not getting the results that we thought we would get with purchasing Concur Invoice.  We're not happy that the Concur Invoice product does not have this feature
1 Reply
Re: Concur Invoice - Importing Tax Amounts and Expense Types at the Line Item Level
We are currently in ECC and migrating to S4 HANA Public Cloud. We are also implementing Concur Invoice. It would be helpful if we can connect and share some ideas. We have the exact same requirement and our coding is oursourced to the actual business departments. It is nightmare to have coders pick expense type one by one and no upload template. I am happy to like the post in the solution suggestion.
I can be reached at samir.shah@kkr.com or 212-230-9739.
Samir
VP - Information Technology.
