sewoong_1
Does anyone know, where is Formula setting for the invoice module?
I know how to config the Request and Expense formula
But I can't find the invoice formula!!
Does anyone know, where is formula menu for the invoice module?
and if there is a guide pdf file for the invoice formula, please tell me which one is it in tech pub
Have a nice day!
@sewoong_1 what screen are you using to create your formulas for Request and Expense?
@sewoong_1 hello there. I'm not sure what you mean by "Invoice formula". Can you provide an example of what you are referring to, please?
sewoong_1
Hi Kevin
Thank you for your reply!
I'm trying to do
1. Field A - Field B = Field C        ex) $100-$50  = $50
2. fill the Amount(Field A)  and choose  a 10%(List Field B)  = Field C      ex) 10% of $100  = $10
something like this
sewoong_1
hi Kenin
as I said first in Invoice module ㅠㅠ  payment header or line item forms
I guess it is not possible to use a formula in Invoice module
Thank you
