vlogan
Using Callout to Post a attendee search request
I am planning to integrate the "Post a attendee search request" from Concur to one of our internal Products to get the HCP/HCO data from our database and show it in the Concur.
I understand there is a connector which should be developed in order to accomplish this communication between Concur and our Product.
https://developer.concur.com/api-reference/callouts/callouts-application-connectors.html
https://developer.concur.com/api-reference/callouts/post-fetch-attendee.html
Is there any more details I can get in order to completely understand how the connector should be implemented etc.
@vlogan I recommend posting this question in the User Admin Group. That group has members that may have dealt with this issue.
By the way, what product are you wanting to connect to SAP Concur?
vlogan
Thanks @KevinD
We have a HCP/HCO expense reporting product for pharma companies and would like to add the feature to search HCP/HCO from Concur on to our Database.
@vlogan My knowledge on this subject is limited, but I can tell you that SAP Concur itself doesn't have a list or data base of HCPs/HCOs. Most of the customers I've come across who are in the pharmaceutical or medical fields use MedPro and connect that to SAP Concur to do searches for HCPs/HCOs. I don't know if this helps or not, but that is the only option I've seen. That doesn't mean there aren't other options, but MedPro seems to be the most widely used.
vlogan
@KevinD , Instead of MedPro, Clients who have our product & SAP Concur, will use the callout to do a search for HCP/HCO in our database and use it in the SAP Concur.
@vlogan gotcha. Callouts aren't my area of expertise. 🙂
