mhenrybayc
Simple Report For Approvers
Is there a simple report that allows approvers to see employees who have not submitted their expense report that are under them in the workflow?
The unsubmitted expense entry report would be difficult for them to understand, I am looking for a very basic report that shows approver who has not submitted their report.
Thank you
@mhenrybayc are you familiar with building reports in Cognos? If so, you can build this report easily. I'll await your reply and go from there.
mhenrybayc
Hey Kevin. I am familiar with building reports in Cognos but would need to know how to build on the report. The most I have done is added custom fields to standard reports.
