How do I handle a charge that was reversed? The original charge is showing, and now the reversal of charge is showing as well. How do I get these to cancel each other out?
@kmarino add them both to the same expense report. That should do it. 🙂
Thank you, I will try this!
Kevin, how can I cancel or edith an approved expense?
@caldepao I looked at your reports and all of them are in a Sent for Payment status, so you will not be able to make any changes to the report.
Hi, I have the same scenario.
An accidental charge that was immediately reversed....however, both transactions now appear.
I have added both to a separate expense report but unable to submit as an error message appears "credit amounts cannot be submitted as personal expenses"
I have tried multiple Expense Types with similar results...including Cash Advance Return/ Repayment.
Please advise.
Thx
@stakaoka The rule causing the red alert is triggered on Entry Submit. This means you need to try and submit the report again to have the condition reevaluated. I went ahead and changed the credit to the Expense Type Other Expense. Go ahead and submit the report.
Let me know if there is an issue.
Thanks Kevin,
I had to attach a receipt to the original charge, but not for the reversal charge.
Re-submit was successful.
Thanks again.
@stakaoka I had a "hunch" it would be successful. 🙂
