leofbernardo
Problems on Expense
I'm trying to report a purchase but appears the alert "You are not eligible to submit Pcard Reports as you have not registered for a Pcard". How can I report it now?
@leofbernardo your company has two expense report types, if you will T&E and P-Card. You tried to use a P-Card report type with T&E transactions. See my screenshots for how to change this on your existing report.
