Hi Team,
Need guidance on how to implement per diem. I have a requirement for Singapore market where I need to enter fixed per diem rate for travel in singapore, international travel in malaysia , inter city travel in malaysia and travel to india. Can you please let me know the exact steps I need to follow
Hi @Saikat ,
You should find this guidance in the standard TA configuration guides. I will add the links below.
http://www.concurtraining.com/customers/tech_pubs/Docs/_Current/SPC/Spc_Exp/EXP_SPEC_TA_XML_V3.pdf
Best regards,
Rohan
Hi Rohan,
Thanks. As I should use the new travel allowance configuration so is this something I can assign manually in rate bundle or its needed via travel allowance import only?
