Pranay
Not able to view expense tab in SAP Concur platform
Hi Team,
Not finding expense option in my Concur platform, please help regarding this issue
8 REPLIES 8
MSteele
If your company changed to the Fiori with Horizon theme, the tabs are no longer showing at the top of the page.  You should see Home with a drop-down arrow next to it in the upper right (next to the SAP Concur logo).  If you click on this, you will be able to see the options that used to be tabs at the top of the page.  If you still have tabs for other products, but are just missing Expense, then you could contact your Administrator to ask why your home page changed.
@Pranay If you could provide a screenshot of your home screen, I can better assist. As @MSteele mentioned, we have a new theme for our UI and things have changed a bit with the layout.
Pranay
I have attached the screen short below.
Pranay
This has happened multiple times.
Nancyagfa
Have you used Concur Expense before this attempt?  You may not be enabled for the Expense portion and your admin will have to complete that action.
Nancy Murray
Agfa
Pranay
No I haven't used concur expense before. How to contact the admin for it ?
Pranay
@KevinD  can you please help
Pranay
Its working now thanks!
