Chrissy-South
My claim was approved, but I forget to fill in a required field
Hey there,
My claim has been approved and extracted for payment.  I just received a message asking about a required field I forgot to fill in when creating my claim.  I can't edit the claim because it has already been submitted.  Is there a way to answer the required question or do I have to start the process again?
8 REPLIES 8
@Chrissy-South In the SAP Concur system, if a field is required but you don't fill it out, you wouldn't have been able to even submit the report. The system is designed to block report submission. So, it's possible the fields wasn't designated as required in the system, but your company prefers you fill out the field in question.
There isn't anything you can do and starting the process over would likely make more work for those reviewing and giving final approval. I think I would just reply to the message you received with the information that should have been entered into the field and see what type of response you get from those that sent the message.
Chrissy-South
Hi Kevin, thank you for responding 🙂   I thought to do that as well but there is no option to respond unless I'm over looking something?
@Chrissy-South how did you receive the message regarding the "required" field? Was it via email or some other way? Was it a message you saw on your actual expense report?
Chrissy-South
Hi Kevin,  yes it's in the actual expense report under expiations.
Chrissy-South
Yes the message is in the actual expense report under Exceptions, but there doesn't seem to be an option for me to do anything.  Even though the claim has been approved should I delete and start again?
Chrissy
@Chrissy-South If it has been approved, then I would do anything unless a person actually reaches out to you.
Chrissy-South
Thank you for responding 🙂   It's been in approved and extracted for payment status for 2 weeks or so... is it normal for it to take this long?  My co workers were reimbursed within 2 weeks of submitting their claim, I submitted my claim on October 19th.
@Chrissy-South Normally, it doesn't take that long, but every company is different. Your manager or someone from the Finance Department might be able to provide better information.
