Is there a way to lock the Employee ID field so that employees can't change it - only Administrators can set and change it. We are using the NetSuite connector and this field must match their NetSuite internal ID which of course no one knows...
@lzarbock I know I've seen these fields locked, but I think you are going to need to contact SAP Concur to have them see if they can lock them for you.
@lzarbock Can you provide a screenshot of where you see the Employee ID field unlocked, please? Be sure to screenshot the entire screen. That way I can provide better assistance.
It's under Profile/Company Information - I'm and admin but even when I "act as another user" it the field can be edited.
Thanks for your help! I'll make a support request.
Hi KevinD - just bumping this up. Did you see my reply below? Thanks for your help!
