cmakai
Routine Member - Level 3
Is there a way to print a listing of your custom Intelligence reports?
I have ALOT of reports out there. I have folders under Team with both Intelligence reports and my own custom reports and I've been asked to create a detailed list.  Is there any easy way to do this without having to hand type the name of each folder, report, and a description?
If so, please share!
@cmakai there isn't any option to print this list out. If it were me, I would drill into each folder and take a screenshot showing the report names. This is probably the fastest way to ge the list without having to type.
cmakai
Thank you. I wish that could work but the list I provide my manager needs to be searchable. It was worth a shot to ask!
@cmakai does your manager not have access to Cognos? I'm asking because they could just use the Search option in Cognos to find the reports.
cmakai
@KevinD She wants a file with a list of the reports and a description as to what each is for; what it does, etc. I'm going to test out an OCR solution someone gave me in the Champions group. I'll let you know if it works!
@cmakai maybe share the report catalogue with her. Here is the link: https://www.concurtraining.com/customers/tech_pubs/Docs/Cognos/DefaultRpts/Catalog.pdf
