Is it possible to reset the initial mileage for Personal car as I have entered the wrong figure?
Dear @Mark1B
I can answer based on a few years back identical case for one of the company's employees I working for.
Ask your Concur system administrator to removing or let you enter again for the first time the starting point mileage. If he is not directly able to do it because not having all those accesses, s/he will open a case with Concur to have it restored for you.
I imaging still the case that individual employees are not able to modify this field as preference settings to avoid wrong personal tax implication.
Please verify within your organization. Thank you.
Dear @Mark1B
Thanks, I thought this might be the case, just wanted to confirm my suspicions.
