Is there a way to import allocations in the Expenses like you can in the Invoices (distribustions)? My company uses this a lot and frequently changes the allocations. It's very time consuming to update and enter manually instead of importing from an Excel spreadsheet.
@cvmike unfortunately this is not possible. However to save some time for future allocating you can save allocations to Favorites. So, if you have a certain way you allocate quite often, you can save this and then apply the favorite to future allocations.
I am having the same issue. Using overhead allocation accounts with multiple cost centers getting a different percentage. Using the "Manage Allocation" template, is there a way for me to do this?
@dschissler I am not sure I understand the question. Perhaps you can add a screen shot to provide clarification. Thanks!
Hi leedau:
Thank you for responding. Below is the info I am trying to set up using a templete.
Any help would be greatly appreciated.
Dave
@dschissler where did you download that template from? I don't remember having ever seen it before? Could you take a screenshot of where you accessed this from, please?
Understand, that was just my data to be input into the below template.
So my main question is how do I enter the percentages for the receivers if they have multiple percentages. See below:
@dschissler As Kevin already asked, where did you get this template from? Is this for Expense or Invoice? Usually, there is allocation favorites.
