I need to expense my managers camper use. Instead of a hotel he stayed at a camping ground for two months and 13 days. Should I submit one bill for the total month or itemize it by month? Would this be considered a misc. expense?
@saxon this may be a question you pose to your Finance team to see what they say. We have so many different members from different industries here, you might end up getting several varying answers.
Personally, I would consider it lodging, but there probably won't be much in the way of itemizing.
Let's see what others think. 🙂
Thanks Kevin, that was my thought process too. I will reach out to finance.
Lisa
Hi Saxon/Kevin,
What if Miscellaneous Expense Type is having limit validation rule on dollar amounts,
@Vizag123 that's a good point, but I wouldn't recommend using the Miscellaneous expense type in this situation. 🙂
The system is allowing me to itemize as a hotel, now I'm off by .03 cents??? Let me do the SAP training.
If you itemized, change one of the line items by the $.03 and save. This works when conversions cause an issue with itemization.
@saxon did you get this figured out? If you enter a hotel expense and itemization is required, what I would do is enter it as a one night stay and then put in the total. This is an unusual circumstance since it really isn't a hotel stay. That way you don't have to break it down on a day by day basis. You probably would want to use the Comments field to explain what you are doing. You might also ask the Finance team if they will allow you to do it this way.
