sachinpunekar
How do I copy and build a Custom Workflow Cycle Time Report ?
I want to copy the standard "Workflow Cycle Time Report" which is present under the Expense Processing folder and customize this report to additional fields like "Report Comments"
When I try to open this report using "Query Studio", I cannot find this report via Manage File> folder of "Expense Processing"
I tried to copy this Workflow Cycle Time Report into a custom Folder and via Report Builder tried to open this report, but again, still cannot find it. The Folder shows all the custom reports I created via Query Studio but not this standard report.
What am I missing? How do I go about this to customize this Standard report?
@sachinpunekar several years back all standard reports were updated and are not Report Studio built reports, so you cannot open them with Query Studio. That is the issue you are having.
sachinpunekar
Thanks for your response. In that case, what is the way forward to customize this report ?
sachinpunekar
Any inputs on how I can move forward on this? Thanks
