e_sherman
Help with building transaction report
Is there a report in Concur I can run to get a list of transactions, by Expense Type, within a range of time and possibly set other parameters?  For instance, if I wanted to find any transactions which took place in 2023 that were:
1) Were categorized in the "Software" Expense Type
and
2) were over $500?
Thank you!
Bibhuti
Hi ,
you can create any view copy from existing Reporting and use 2 filters I created for you:
[Expense].[Commonly Used Fields].[Expense Type] like '%Software%'
[Expense].[Entry Information].[Expense Amount (rpt)] > 500
joffyjob_krones
Hi @e_sherman
You can use the below Standard Report:
Intelligence - Standard Reports > Expense Processing > Expense Entry Analysis
@e_sherman I'll echo the other two who have replied. You can use the Expense Entry Analysis and just choose Software in the Expense Type prompt. I don't recall if this report has a date prompt to choose a date range, but my guess is it does.
You could also build your own report. I don't know your report building comfort level, but I can say this report would be quite straightforward to build.
