please help. I am continually getting this message when inputting my claims
Missing receipt declarations not permitted for cash reimbursement claims
It is a cash claim and yes I do have a receipt loaded
@annechristie is the message denoted by a red circle or yellow triangle?
If red, then there is some sort of issue with the rule causing the message. If yellow, it is just a reminder and will not affect you being able to submit the report.
Look for a field called Receipt Status or Receipt Type, and check that the value in the field indicates that you have a receipt. It doesn't automatically change when you attach a receipt to the expense.
