PEKELL
Expense Workflows - at Expense type level
Does anyone know if it is possible to create a workflow that will be assigned to an approver/group when a specific expense type has been selected?
@PEKELL Hello there. When I first read your question, my initial answer was no. However, due to overwhelming curiosity, I tried doing what you asked about and to my surprise, I was able to get it to work.
Now, the question to you is, do you have sufficient permission in the SAP Concur system to modify workflows? Most people do not have the permission. If you or no one at your company has this permission, then you will need to submit a support ticket to get this done.
In my test, I set up a workflow step to change approver to a specific approver, so I don't think you can do this for a group of people. I used a specific expense type and basically told the system if the expense entry equals xxxx expense type, then send to ABC Approver.
Let me know if you have any other questions.
PEKELL
Hi @KevinD , That is great news, and happy someone else gets curious about these things.
Did your test reveal that if you have multiple expense types in a report, but one of the entries are for the expense type XX, the whole report reassigned to the Expense type XX approver?
I am investigating the permissions now (as I do not believe I have the appropriate access to view/amend workflows in Concur).
Thank you , really appreciate your assistance
DeanR
Hi @PEKELL ,
We've had such a rule in place for a number of years, set up and maintained by Concur Support.
If the rule is triggered by a report where any of the expenses use the relevant Expense Type, then the whole report gets reassigned to the approver specified in the workflow rule.  We only have one Expense Type with this rule and we advise users to do a separate report for those expenses to work around this.
Cheers
Dean
@DeanR thank you for providing the clarification and the suggestion. 🙂 Haven't seen you here on the Community for a little while. Nice to see you back.
