How long are expense reports kept in Concur? Are they ever purged by Concur?
@dlamont they should keep them indefinitely, unless some sort of data purge is requested. However, I don't know if Expense Report data is something that can be purged.
Thanks Kevin, I didn't think they were ever purged or deleted - needed to verify for accounting!
@dlamont all I can say is that I have never heard of purging expense reports happening. 🙂
