z004kcaf
Error in introducing the business purpose for travel expenses
Dear Team,
When I try to introduce the business purpose for the travel expenses it appears the following error:
I have tried to refresh the page and also sign out/sign in, it didn't work.
I kindly ask you to give me your support on that.
Thank you in advance for your help.
Looking forward to your quick response.
Best regards,
Monica
@z004kcaf and @wabbott2022 if you are still experiencing the issue, try using a different browser to see if the error still persists. This helps us narrow down whether it is a browser issue or the tool itself.
wabbott2022
I am experiencing the same error message.
z004kcaf
Dear Kevin,
Thank you for your quick response, I have tried to use a different browser - chrome, it appears the same error.
wabbott2022
I switched to Chrome and that appeared to fix my issue.  When I use MS Edge, I cannot add text to the "Itinerary Name" field.
