Hi Concur Experts,
I am trying to edit the default employee form to create new expense users.
Under Administration > expense administration > Forms and Fields - The employee form is not available in the dropdown (Refer attached screenshot).
According to this document, the form should be present in that dropdown: https://www.concurtraining.com/customers/tech_pubs/Docs/_Current/SG_Exp/Exp_SG_Forms_Fields.pdf
I can see the employee from under Administration > expense administration > configuration report but can't edit the form fields there.
Why is the employee form not visible in the dropdown ? How else can I edit the employee form ?
Thanks for your suggestions.
Hi @Parth_Concr ,
Unrestricted is super admin access, which is assigned to an admin user profile using which usually implementation configuration is done.
You will not find this role listed under user permissions.
You can check internally whether anyone has unrestricted access to configuration.
If are working for any client implementation project and need to configure entire configuration for specific new legal entity or country, then you must 1st get unrestricted access from Concur to your admin profile then only you will be able to see employee form.
If you are working on only on support activities for any client and configuration is already done previously, then you will not get that access from Concur.
@Parth_Concr that is odd and the employee form should be there. Strange all the other forms are there. I would suggest submitting a help ticket.
If you know anything about that Kevin, i'd appreciate
hello, may I ask what was the solution? I've got the same problem.
Hi @Parth_Concr , @jps ,
Employee form is not visible because you have Expense Configuration Administrator (Restricted) access.
To access employee form you must have Expense Configuration Administrator (Unrestricted) access.
To confirm my solution, I tried giving restricted access to one of my test user profile and I could, employee form is not visible into my test profile.
Once your query is answered, please mark solution as accepted.
Hi @PoojaKumatkar ,
I cant find the Expense Configuration Administrator (Unrestricted) role in my tenant. I cant see any "Unrestricted" role.
Can you please confirm if role is to be assigned through Company Admin > User Permissions or is there some other way to find the unrestricted roles ?
Thanks for you suggestion.
Hi @Parth_Concr ,
pooja you're the best thanks.
