ngbharadwaj
Data flow from Concur Travel to Expense
Hi - I'm trying to understand how a company can benefit from using both Concur Travel & Concur Expense. What data flows from Concur Travel to Expense and what additional benefit will the company gain if it has integrated card data flow? Thanks in advance.
Cheers!!!
@ngbharadwaj see my responses in red.
A company to integrate data flow from multiple cards
    a. Corporate Credit Card & Central Card(e.g. Amex BTA) - Use Central Card for Air Purchase and Credit card for Hotel? This is possible and quite common with our customers using Concur Travel & Expense.
    b. Corporate Credit Card & Employee Personal Card - Should there be a situation for the employee to use personal card
         and the get expense line captured in Concur Expense? You can have both a corporate card and the option for employees to connect their personal cards through what we call Yodlee. Transactions from either card will automatically flow into the users' profile. The Yodlee feature needs to be turned on in the Group Configuration.
@ngbharadwaj the data that flows from Concur Travel to Concur Expense are the booked itinerary items (Flight, Car Rental and Hotel). It allows users to more easily get those items added to expense reports and allows for better tracking of total trip cost.
By integrated card data flow, are you referring to having a corporate credit card integrated with SAP Concur?
ngbharadwaj
Thanks @KevinD for the response and the information of data flow from Travel to Expense Module.
Yes, I'm referring to Corporate Credit Card integration to SAP Concur. While at this, is it possible to have the following
1. A company to integrate data flow from multiple cards
Sorry for the add-on questions :-).
