GB1
Concur mileage expenses :: Mileage calculator not working
Error says, "Oops! Something went wrong. This page didn't load Google Maps correctly. See the JavaScript console for technical details." Screenshot below.
@GB1 this is a known issue and SAP Concur is working on it. If your company doesn't require the mileage calculator, you can go straight to Google Maps to enter your addresses and get the distance to manually enter on your expense report.
GB1
Thanks for the reply @KevinD . Have they provided any type of ETA for this? My company won't allow us to input mileage without either that calculator/map or the tracking feature turned on. While I don't intend to do the tracking that isn't an option for previous days.
@GB1 I haven't heard of any ETA, but I did post this in an internal Slack channel to see if I can get an answer.
@GB1 you might already know this, but the issue has been fixed in the U.S. Our team is still working on the fix for the EU.
NH001
Issue now resolved - thank you for your update.
NH001
All is good now - Thank you for addressing the issue.
