raghav3180
Concur Cognos & Power BI integration
Dear Community,
We wanted to explore the options around the Concur Cognos and Power Bi integration.
Can you please share some thoughts about this integration?
Please recommend if there are any pre-developed connectors.
Thanks for your input.
jessek21
If you have Cognos reporting - you can FTP reports to a datawarehouse. Or you can integrate via API but this requires the webservices to be on your Concur contract.
FTP Concur reports - https://www.concurtraining.com/customers/tech_pubs/Docs/FactSheets/FTP_Cognos_Reports_Delivery_Fact_...
Concur reporting API - https://developer.concur.com/api-reference/common/extracts/v1.extracts.html
