wtemple
Comments Required for Transactions Larger than.....
I am trying to set up a rule that requires people to enter a comment anytime there is a transaction larger than $500.00. I am currently using "Amount" as the Field/Value however, it does seem to trigger a warning to enter a comment when I t5ry and test it.
Any ideas??
@wtemple your rule should have two conditions:
1. Transaction amount is greater than $500
2. Entry Has Comments Equals No.
For the exception, make sure it is set at a level 99 so that this will be a hard stop.
wtemple
Is this how you would have it set up? I used "Amount" in the field/value as I did not see a transaction only option
