Rasmus_GEA
Automatic allocation of per diem and travel allowance
Hi community
A colleague in the same firm and same department is using the same concur expense mobile app as me but in "his version" when logging in the per diem and travel allowance automatically allocates the expenses. This is of course if he have made the expenses beforehand and logs in after the dates of the expenses. The thing is, on the Mobile app I have to go in on each date with per diem to allocate manual.
How do I get it to do automatically when logging in? Am i missing a setup?
Br
Rasmus
rohanpatil
Hi @Rasmus_GEA ,
I understand that in the new version of Concur Request, it is possible for approved travel request to automatically generate an expense report. As per the documentation, below are the conditions that must be met for the feature to behave as expected:
  • the feature is enabled
  • the request is approved
  • the start date of the request is "now or in the past" (meaning the trip has started)
  • no other expense report has been associated to the request
Based on your comment that this works for your colleague, it seems that the feature is enabled for your company. Since this does not seem to work for you, I would suggest that you raise a case with your internal support team/ Concur administrator. They can look into the details of your requests and advise why the auto-creation is not working for you. Hope this helps.
Best regards,
Rohan
Rohan Patil
Rasmus_GEA
Hi @rohanpatil
Thank you for your reply. A few comments from my side.
    • I dont know. I will ask our accounting.
    • This is an ongoing travel expense and when my colleague open the expense report it allocates per diem in the "past" automatically.
    • Yes it is.
    • Nope.
Best regards
Rasmus
rohanpatil
Thanks @Rasmus_GEA. I am intrigued but cannot provide more insights on how it is working for your colleague.
Perhaps @KevinD  can provide a bit more insights into the setup at your company
Best regards,
Rohan
Rohan Patil
@Rasmus_GEA it is really difficult to answer this question as we don't know what your colleague is doing as compared to what you are doing. Is your colleague signing in on the web version and attaching the itinerary to their expense report there? Is your colleague only using the mobile app? Are you only using the mobile app? There are a lot of questions that would need to be answered.
The only way per diems are created is by creating a new expense report and selecting that travel allowances need to be reported. Then you would assign an itinerary to the report. This will then break out the per diems.
The system does not automatically break out and add per diems to an expense report without some action by the traveler. So, my guess is your colleague is assigning an itinerary to their report.
Rasmus_GEA
Hi Kevin
As i write in the beginning we are using mobile app, same version, and are doing the exact same routine. So we make a travel plan with per diem one month ahead fx and then if he logs onto the mobile app it will allocate the per diem up until the date when he logs in.
Best regards
Rasmus
@Rasmus_GEA So I'm clear on what is happening...when you create your travel plan with per diems, you are not seeing the daily allowances on your expense claim when you view the claim in the mobile app, but your colleague is able to see all the daily allowances on their expense claim in the mobile app? Is that correct?
