Hello team, I hope everyone is well.
We have here in our expense types (Mileage and Fuel), but I would like to block or alert when both types of expenses are included in the report, is this possible?
Hello @MIRANDA
You can certainly do this in case you have the Professional edition. You can refer to conditions and possibilities in the audit rule documentation.
In your case the alert can be on entry save. Condition can be to check if entry expense type in Mileage or Fuel and message can be with level 1(warning) or 99 (error).
https://www.concurtraining.com/customers/tech_pubs/Docs/_Current/SG_Exp/Exp_SG_Audit_Rules.pdf
Hope this helps
Hi Miranda
Are you an end user or a processor?
If you are a processor and want to search for reports with 'expense types (Mileage and Fuel)' in the end users' reports, please follow these two steps:
Create an audit rule
Create a query on the Expense Processor view
Hello @MIRANDA
Hope this helps
Hi @rohanpatil
Thank you for sharing the file on audit rules, I will study it and if I have any difficulties in developing it, I will turn to the experts.
@MIRANDA so, now that @rohanpatil has let you know what you are asking is possible, the question is...How familiar are you with creating audit rules? 🙂
Hi @KevinD
I have already had the opportunity to modify the audit rule and after testing it was approved by the applicant.
However, in this case I was in doubt (I admit), I will read the documentation sent and if I have any difficulties I will contact SAP Concur support.
Thank you
Hi Miranda
Hi @SNLee89
Thanks for sharing your experience, I'll read about the topic a little more before applying your solution.
