frnkgom
Accidental personal charge on Pcard
Hi team,
I made an accidental personal purchase on my new Pcard. I was able to get the charges reversed to my personal CC. The issue is the initial charge and the refund is showing in Concur. I do not know how to clear out, is there a trouble ticket I could cut? Any help would be greatly appreciated!
-Frank
@frnkgom choose the expense type that matches most closely to what was purchased. For example, if you bought a new mouse for your computer, choose the expense type of Office Supplies or whatever expense type your company has that is similar to this. Be sure that you use the same expense type for both charges.
@frnkgom add both transactions to a report, they will zero each other out. :-). When this situation happens, treat the refund as any other transaction.
frnkgom
Thank you for the response KevinD ! I do not see a an Expense Type in the drop-down menu for this situation. Would I choose a  type closest to the situation? I did try "Undefined" and clicked the Personal Expense (do not reimburse) box. The system will not let me move forward without  inputting a valid expense type. Any suggestions?
frnkgom
Thank you Kevin! This solution worked great! Thank you for you time.
@frnkgom Glad to hear it was resolved. 🙂
