"Help" widget
How do you disable the intrusive "help" widget?
Accepted Solutions
Re: "Help" widget
It can be removed, but someone from Concur needs to do it for you, I believe. So, whomever you worked with in your implementation should be the person you can reach out to and ask.
Re: "Help" widget
Are you referring to the Question Mark in the blue circle? If so, if you mouse over it, a little X will appear you can click to close it.
Re: "Help" widget
That's the one but you have to close it every time you navigate to a different function.  Can it be permanently remocved?
Re: "Help" widget
