Patricia
Updating Message Text in email set to Notify New Users
Due to an issue in the feed, I currently need to set up all new users  manually into the system. Currently at the end of the new user set up there is the email parameter box that will send an email to the user letting them know their username and password. Has anyone had expereince changing the text.
Dear [FIRSTNAME] [LASTNAME],
Welcome to Concur! Your Login ID is [LOGIN]. You can access the site and change your password using the following link:
[LOGINURL]
After you change your password the link will immediately expire. (It will also expire after one week).
0 REPLIES 0
