ajbrowncolordo
Where can I find Employee position/title in the Cognos Concur Data Warehouse?
I am trying to add the employee position/title in a report in Concur, but I cannot find that field in the Concur Data Warehouse when using Cognos.  Does anyone know where I can find that or add it into my report?
Thank you.
That data is not there by default. It will only be there if you have created a custom field on the Employee Form and have filled out every employee's position on their profile as a user administrator. If you send me a private message with your full company name, I can go in and take a look and let you know if it indeed is a field you are using on the Employee Form and if so, where it will be in the data warehouse.
