Re: Understanding Reports Approved But Receipts Not Viewed
Hey @SandraA, this may be a dumb question, but how did you make changes to the report? Is this a function easily done in Professional / Intelligence? We have the Standard / Analysis platform and I'm unable to see a way to change a standard report. I can copy it and create a Report View version of it, but I can't adjust any filters, fields, or anything else.
Josh
Hi Josh ,
Yes this is an example of what you can do in Intelligence and not in analysis.  I wouldn't say it was easy - because the report design gets pretty complex and it's especially hard to reverse enginer the Concur created reports.   We do have full access to either change the report design or create our own reports.
It seems like it would be possible to create this report in analysis.
Sandra Ahola
T-Mobile
US
