Tax code
Hi all,
Our company is implementing the Concur Expense at the moment.
We encountered below error message during one of the posting.
Very much appreciate your advise if anyone have experience on solving this problem.
Thank you in advance and have a nice day..
Posting failed. Check customizing for tax code E3 of country IN.
Message No. CTE_FIN_POSTING006
Diagnosis
The Concur tax configuration doesn't match the SAP tax code. For example, even though an SAP tax code is configured with 0%, a tax amount is still calculated and transferred from Concur.
Procedure
Please correct the Concur tax configuration accordingly, or select a different tax code.
BK
Re: Tax code
According to our SAP FI consultant, Both SAP and Concur is having the same tax code E3.
So its no clue for us where is this error get triggered.
SAP Concur, Former Employee
Re: Tax code
Thanks for posting!
Have you created a support ticket for this? They should be able to provide support for your specific configuration.
Ashley Bragg
Re: Tax code
Hi Ashley,
Our FI consultant raised ticket to Concur consulting team. But they don't have solution on this.
I'll ask our FI consultant to communicate with them again. If any feedback from them i'll reply to this thread.
Thanks and stay safe. Lockdown happens everywhere due to the Covid-19 pandemic.
BK.
Re: Tax code
Hi @bktey1688
Thanks for the context! I am glad to hear you have the support you need and a plan in motion. That sounds great. We appreciate any future updates on this thread. I am sure others would benefit from the solutions you find.
I hope you are staying safe as well!
Ashley Bragg
Re: Tax code
Hello.
What it means is that tax code E3 has been used in Concur and has a percentage associated with it. But SAP does not have a tax percentage for this tax code.
Use transaction FTXP and provide a tax percentage for this tax code E3 and the tax condition which applies to it. While you are at it, please make sure the tax GL is also provided for this tax code E3.
