Selective Audit criteria to include particular expenses
We currently have audit selection criteria which is a mix of reports above $ threshold and random selection of fixed % of balance reports. In addtion to the existing audit selection is it possible to include reports having a specific expense type to be always selected for audit.
Accepted Solutions
Re: Selective Audit criteria to include particular expenses
Hi kishoreapv,
You should be abel to achieve this via audit rules.  Simply set a rule like this:
Entry | Expense Type
ANY, In
Value | "Your expense type(s)"
Then set the exception to the level that triggers your audit (ours, for example, is 71).  With that in place, any report with any expense in "Your expense type" will go to audit.
I should mention that I don't know if the process is exactly the same if you are utilizing Concur Audit services, but if you are not, this would definitely work.
Best of luck! Smiley Happy
Hi kishoreapv,
ANY, In
Thanks a Ton Merin.
