The message you are trying to access is permanently deleted.
That should do it for you.
I have the same issue. When using the SAP concur app last year, all the photos I took with the expensit button would save to my iPhone. But since using the app in 2019, it has not saved a single photo with the setting correctly activated. I now have a missing receipt that I cannot submit because I lost the original.
I also want to understand why when I take photos using the app, they never save in the "available receipts" section on the website. Even last year I have never seen this happen. Ever! I also called to report it but nothing has changed.
Hi @1000263209 @richardspies @KevinD ,
Good day.
AnnaDizo
Richard
I am having the same troubles. When will this be resolved? The save photos option is enabled but the receipt is not being saved.
When will this be resolved? For me the images don't save to Photos when I have ExpenseIt enabled on iOS; if I disable ExpenseIt they do save to Photos, but we really need it to work with ExpenseIt as we're trying to push that feature.
Hi @Flempitsky
Have you created a support ticket for this issue? That would be a good place to start. You can do so through your company's authorized support contact or the User Support Desk. You can reach out to your company to learn which channel they prefer.
Hope this helps!
Hi @richardspies @Flempitsky @DeanR @Brentahayden ,
Good day.
The issue on receipts not saving on devices even though the setting is enabled is still an ongoing issue that R&D is continually working on. Just an update: For Android devices, issue will be addressed on the release of Concur app version 9.71, except for a small corner case that will be addressed in 9.72. For iOS, we are still working on it.
AnnaDizo
Thanks for the update. This is really a problem for us, because users (especially execs) don't want to have to keep the paper copies of receipts once they take the photo. We've gone to great lengths to train them to use and trust the mobile app. So, this definitely has high visibility and impacts the perception of the product.
Hi @MMAUST ,
Good day and Thank you for reaching out.
To properly assist you on the issue raised, are you referring to saving photos to the device's gallery after capturing them via the Concur mobile app?
Please advise.
AnnaDizo
Yes, because that's what this thread was about. When I take a photo with the Concur Mobile app, I would expect the setting "Save receipts to Photos" to save the receipt image to the camera roll on the phone. But, the image is not saved. Seems like a minor thing, but with the relative frequency of Concur Mobile issues, its vital to have the image saved so it can be processed again later.
Settings:
ExpenseIt = On
Expense Assistant = On
Save receipts to Photos = On
Hi @MMAUST ,
Thank you for your confirmation.
With the new 9.71 app version on Android and 9.71.2 on iOS, have you tested if the issue is still happening?
AnnaDizo
Hi, Anna:
I just updated to 9.71.2 on iOS. It appears this was just released on August 9th.
While there are no mentions about this in the release notes (which I read every month), it does seem the images are finally saving, as expected, to the camera roll.
Thanks for highlighting this new development for us.
-Michael
HI @MMAUST ,
Good to hear that it is now starting to work. Once the 9.72 is released, a full fix will be implemented with regards to this issue.
Thank you again,
AnnaDizo
This is also working for me now after installing iOS v9.71.2.
