Anonymous User
Not applicable
New Expense UI - Expense Assistant?
In the new UI, how do you activate the Expense Assistant for an employee?
Accepted Solutions
Re: New Expense UI - Expense Assistant?
Greetings,
While Expense Assistant feature is available and working in the NextGen UI,  the "Try it" trial does not display to the user like in the current UI.
In NextGen UI, the Expense Assistant function may be enabled from the user’s profile in Expense Preferences.
More information on features not yet available here:  http://www.concurtraining.com/customers/tech_pubs/NextGenEXP/UpcomingEnhancements.pdf
- Clay Thompson @ SAP Concur
Greetings,
Anonymous User
Not applicable
Thanks @ClayT!
Of course! Let us know if that worked for you.
Anonymous User
Not applicable
It sure did; thank you!
