I am currently testing the new Concur version in production. I have been unsuccessful in getting the allocation functionality to work as expected.
I added an additional Cost Object ID to the allocation screen. I changed the percent to 50 so that the amount is allocated between a cost center and WBS Element. The screen shows the remaining balance is $0.00.
I then selected the SAVE button at the bottom right hand of screen. A red alert appeared indicating that the allocation is not 100%. Again, the previous screen print indicated that the remaining balance is $0.00.
I have tried allocating between two cost centers and got the same results.
Please review and advise when this issue will be resolved.
Hey @grimmki,
Welcome to the community!
Do you have a screenshot of this error? If you could upload one here, we could take a look and maybe see what could be causing this issue.
Also, do you have any Custom Audit Rules surrounding Allocations? If so, could you let us know the parameters of those rules?
Issue has been resolved. I failed to add an extra line for allocation.
