SAP Business Exchange
tstagliano
Line Item Rejection Listing
Has anyone been able to generate a report of all the expense items that have been rejected or sent back to the employee via the Send back Expense checkbox available on the expense form?
Thomas Stagliano, M.I.T.
Re: Line Item Rejection Listing
I don't think this is something that can be report on. I searched to see if there was a data item labeled "Send back expense" in the data warehouse, but nothing came up. So, I'm thinking that there isn't a way to build this report. I am not 100% sure, but @TRedman might be able to confirm or deny this. :-)
If an expense report is split, a portion is approved and sent on for payment, and a portion is returned to the employee.  This creates an addendum expense report.  The new report has the same report name, with the word "Addendum" before it.  The Addendum report has a new Report ID & Report Key, but the originals are listed in the comments or audit trail.  There is not a direct connection within the data between the two reports, but you can identify the original through those data points.  It is not a clean report, but you could build something which the report name contains Addendum.  This won't be a 100% accurate, as a user could change the name of the addendum report but could get you close.
Hope that helps!
Tiffany Redman, Senior Product Manager, Data Platform and Analytics
