malithih
Is it possible to assign an employee to multiple company codes
I have a requirement to create the same employee under two different countries with two different cost centres. Since the email ID is same it doesnt allow me to proceed. Is there any other way to assign a single employee to multiple company codes.
Thank you
Malithi
First off, why do you need to create an employee under two different company codes?
As a work around, you could create a second profile using a different login ID other than their company email address. Maybe use their personal email address for their second profile. So, they would have two separate profiles in SAP Concur. That's the only way I can think of to accomplish what you want.
Maybe someone else on this forum has a better solution.
