DH
Field Codes for Attendee Status
Hi Concurrers,
I'm trying to setup the Attendee Import Template and include the Attendee tatus Field to capture traveling and non-traveling employee details for AU FBT purposes - does anybody have an example of a attendee import template including these fields or alternately the Field Codes for the Traveling and Non Traveling options?
David
