Expense Assistant Expense Report Naming
Is it possible for the admin to change the defult naming of expense reports when end users use the Expense Assistant to create reports? The report naming being used by the expense assistant does not follow our current expense report naming convention standards.
Accepted Solutions
Re: Expense Assistant Expense Report Naming
The default name is not configurable - but it is editable.  The user would need to change the name to match your naming conventions.
I don't believe this can be changed. Maybe there is another Concur person in this group that knows differently, but I'm fairly certain (not 100%) that it cannot be changed.
