Cognos - processor / report - how many reports were audited
I want to create report, which will show me how many reports were processed by a specific person (processor within T&E department), based on some dates.
In previous company that kind of report was on the list in standard reports, here I cannot find any / simillar to that one.
Is it possible to create that kind of report?
Thank you in advance!
BR,
Łukasz
Re: Cognos - processor / report - how many reports were audited
Hello Lukasz,
Yes, Of course.
There is one Standard Report already available i.e. 'WORKFLOW CYCLE TIMES - SUMMARY BY PROCESSOR'.
This report contains the below details:
Reporting Currency: ABC
Processor Name
Report
Count
Approved
Amount
EntriesExceptions
Average
Days
And yes, also there is a possibility to create this report in Report Studio.
Cheers!
Br,
D Kumar
Hi Kumar, Could you pls specify the exact name of the standard report? I am not able to find:WORKFLOW CYCLE TIMES - SUMMARY BY PROCESSOR
Many thanks!
@Adriana It is possible that your company does not have the buy up version of Cognos reporting. The buy-up version has access to over 100 more standard reports. This may be the issue.
Do you know if your company has Business Intelligence? To know this, when you log into SAP Concur on the home screen where you see Reporting, does it say Intelligence or Analysis in the drop down? If it says Analysis, then you won't be able to access this report. If you see Intelligence, then you should be able to see this report.
Hi Kumar,
thank you for response!
I've checked once again if we have that kind of report, but I checked all categories and reports that are in each folder and cannot find the report, you mentioned above.
In which folder I should have that report?
Administration
Audit
Carbon Footprint
Company Billed Cards
Compliance
E-Receipt
Expense Processing
Finance
Fraud
Invoice
Market Specific Reports
Meetings
Mobile Usage
Persona Dashboards
(or maybe we don't have that one due to some version differences?)?
Kumar, are you able to check which columns / fields are taken to that report?
BR,
Łukasz
