Re: Android receipts -crashes
Hi @TrishW
Good to know it all works fine now.
Anna
I'm having a user experiencing this same issue with the app crashing while taking a photo of receipts while running Android 7.0.  Is this version of Android part of the baseline for Concur?
hi, having this issues on various OS versions (android) and various devices:
OS 7, 8, 9
samsung S9, note 8,9, google pixel 2,3
is there any kind of work being done on this?
Hi @CGJoseC
Good day.
Android OS 6 would be the minimum supported version.
Kindly provide me more information of the device used:
Specific device type(Samsung, Lenovo, Huwawei, LG):
Device OS version:
Device Language:
Device Model:
Concur app version installed:
Are you using the Receipt camera icon or ExpenseIt camera icon when taking picture?
Step by step process on how affected user captures receipts until the time he/she gets the crash?
Please advice.
Thank you.
Regards.
AnnaDizo
Hi @_vn_
Specific device type(Samsung, Lenovo, Huwawei, LG):  samsung S9, note 8,9, google pixel 2,3
Device OS version: OS 7, 8, 9
Device Language:
Device Model:
Please advice.
Thank you.
Regards.
AnnaDizo
I am trying to use Concur on my OnePlus6T (Model: OneplusA6013)
OxygenOS: 9.0.12
Android Version: 9
Buildnumber: A6013_41_190123
It constantly crashes on startup.
Is this a common issue that you are aware of and fixing?
Is there a quickfix or guide?
Hi @MC ,
This is an existing issue on Android that started when OS 9 was released. There was a security patch update that Google did on this OS version that caused the issue to happen. Some OS 8 and some 7 are also affected.
If I may ask, are you using MDM, MFA, 2FA, WorkProfile or WorkSpace?
AnnaDizo
I have a few users intermittently having the same issue. One in particular is running Android OS 7.1.1 with a MotoE 4+. App crashes and is not able to accept some receipts. Please advise.
Hi @kpierson
Is the issue still happening?
If you can kindly provide me more details of the issue like the step by step process before the crash happens? Also details on the device you use like Model, OS Version and Concur App version installed?
AnnaDizo
Same
