joeabraham
Under Analytics and using Expense Accrual, am I able to add Custom Fields as headers?
We're trying to accrue cost based on information that comes from our Custom Fields.
@joeabraham I was looking around at your company's account and I see a case was submitted to switch your company from Analytics Essentials to Analysis. The case notes said this was done, but I still see Analytics.
I'm mentioning this because if you do switch to Analysis, what you are asking is possible. However, until then you won't be able to customize your reports with Analytics Essentials.
joeabraham
That's correct, I see Analytics as well. Should we be under Analysis?
If not, is there some type of workaround to get this information?
@joeabraham Oh my gosh. So sorry, I was looking at a different company's request to move from Analytics to Analysis.
See my screenshot below that shows the steps on running a report in Analytics using Cost Tracking fields. Let me know if this helps. Note: This is an example using the Expense Entry Analysis Details report, but it should work for any standard report you see.
