KFriedhoff
Static Coding for HST, GST, QST Tax
We have 3 segments plus the natural account in our coding string: Company, Location, Department and Natural Account.
For Canada tax, the coding segments should not match the employee's profile but should be a static coding. For instance, GST should always be 300(company).540(location).0000(dept).218156(natural).  This coding should be the same for all employees and listed on the SAE as such.
Can this be setup? I have not been able to figure out how to do it.
Karen
@KFriedhoff ahhhh. Okay. Well, I went into your site and looked and it appears you are using the Default SAE. When I went to that screen, the options were grayed out, so for me it was locked.
You probably will need to submit a Help ticket to Concur Support to see if you can switch from the default SAE to a custom one.
KFriedhoff
@KevinD - Good morning Kevin. Can you help with this question?
@KFriedhoff what screen are you using to try to make this change?
KFriedhoff
@KevinD  I do not know where to add it so the segments are entered correctly for the SAE.
KFriedhoff
Thank you
