I cannot figure out how to export data from the Spend Analysis page in Analytics to excel. When I click the three dots in the right corner, I only see "information"
I am viewing as "Finance Administrator". I also tried viewing as "Manager" and had no luck. Those are my only two viewing options
My only contact with Concur is no longer with the company and the sales contact I have is not responding to my emails.
I need this report in excel urgently for our CPA.
Thanks for any help.
@Shannon1 The Spend Analysis is a Dashboard, not a report. That is why there isn't an Excel option. The dashboard does display the Expense Entry Analysis Details report, which is listed several items below the Spend Analysis. You can open this report and export to Excel.
Thank you Kevin! After digging around for a while, I actually just figured this out! I exported to excel and the formatting is not compatible (I cannot change the date format and the numbers are not recognized, so the sum function does not work). Do you know how to fix that?
@Shannon1 Okay, I was able to get the date format to change. I went into Format Cells>Date then selected the new format. The dates didn't change until I double-clicked into the field. Not ideal, but it was able to change.
As for the sum function, I'm not sure how to fix it.
thank you Kevin!
@Shannon1 it appears you do not have to change the format using Format Cells, but just double-click in the fields with the dates. 🙂
@KevinD - Is there a way to choose the report to show based on three months as well?
how do I summit my receipts?
