Hi All
When on the 'Manage Expenses' page in Concur (using the website) if I drag an invoice/receipt from my computer hard drive onto the red 'Upload New Receipt' box an image of the receipt appears to the right of the red box, but the same receipt does not appear in the list under 'Available Expenses' hence I can't match the receipt to an expense... so whats the trick to getting receipts in that list? I can get receipts into the list if I take an image of them using the phone app. Is this the only way? Seems a little clunky if so Any help hugely appreciated.
Stewart Kelly
Murdoch University
Western Australia
@stewmurdoch the image will not go into Available Expenses. It will go into your Available Receipts though. Then when on your expense report and you want to attach a receipt to the entry, you click Add Receipt. On the window that opens, you should see the image you uploaded. Here you can select it and match/attach it to the entry.
Cheers Kevin!
Stewart.
Hi
is there anyway to get the receipt/images into the area where it can get automatically matched? Would sending the receipts to [email protected] work?
The reason I ask is that we moved credit cards recently but has taken 3 months to get the feed into concur and so we have a large number of transactions that need to be put into claims etc and I want to see if there is a smart way to do this? Also, is there a training video on the MATCH and UNMATCH process? Any guidance much appreciated.
You would need to be licensed for ExpenseIt to be able to submit receipt images to Available Expenses via email.
@SharronL receipts sent to [email protected] to do not get matched automatically. Only E-receipts and receipts processed by ExpenseIt will auto-match.
There isn't any video about matching that I know of.
Thanks Kevin
Thank you for clarifying Kevin.
