- Mute
- Subscribe
- Bookmark
Personal Car Mileage not saving
I have been using Concur to all of my travel expenses. Everything has worked well until recently. When I try to submit
my mileage expense, there is no save button on the bottom. All I have is the mileage calculator. I use this option, but still cannot save my Personal Mileage. I am using the new web version. Has something changed? Here is my screen with personal details removed
- Mute
- Subscribe
- Bookmark
Hi Kevin. I did some more digging and this is a Firefox issue like we discussed. Firefox did 2 updates in the past few weeks , and this is when my issues started. It is also affecting my Salesforce application. I switched to Chrome and everything is working like it should.
- Mute
- Subscribe
- Bookmark
@rkolb1 based on the screenshot you provided, you are missing required information. Can you take a screenshot of your entire screen, please? Without seeing the entire set of fields and buttons, it will be difficult to provide guidance.
- Mute
- Subscribe
- Bookmark
