slsvb1
Need for more in depth reporting
The reports offered seem to be little more than a rearrangement of what can be displayed on the screen.  If I want to know:
  1. How many expenses are being submitted this month
  2. How many expenses are being submitted this month without a receipt as a percentage of the total number of expenses
  3. How much is spent in each category
  4. Number of expenses by category
  5. Expenses by custom date range (Credit card statement period vs calendar month for example)
  6. etc...
How to do?  Crystal Reports would do this nicely if there was a way to get to the Concur data.  Is there a way?  Is there an API?  Maybe I could write my own way to query.
Please offer suggestions.  Thanks.
@slsvb1 we don't have an API to link our data warehouse with Crystal reports. I'm pretty certain everything you mention can be done in Cognos reports.
Are you familiar with our Cognos reporting tool?
slsvb1
I'm familiar with Cognos only enough to know that it's an unwieldy, cumbersome tool that requires more experience than I have in order to use it effectively.  I'm guessing I'll just have to learn to live with what little Concur can present on the screen.  🙄
Nancyagfa
If you have access to Cognos, look at the standard reports listing that are offered and you may find reports that have what you want to review.  I have Intelligence and look in that report folder before I contact reporting for a specific type of report.  Cognos reporting can also take the standard report and customize it with your request.
Nancy Murray
Agfa
slsvb1
Unfortunately I don't have access to Cognos.  This thread may be closed as, "No solution available".
