Astepp
Mileage Calculation Problem
I take the same route everyday to the doctor's office, but when
I go to the hospital it doesn't calculate the mileage right lately.
It is a little further. What am I supposed to do? I haven't turned in
my August report because of this.
@Astepp okay, I accessed your expense report and did a couple of tests. You are required to use the Mileage Calculator. However, what can speed up the process since it is the same route each time is to select one of the line items in your report (I recommend the most recent and use the checkbox), then use the Duplicate option. This should copy everything, including the route, and create a new line item with one day added to the date of the copied item. Give this a try and see if it works for you.
